Modicon M580 PLC - Comparing DateTime
joeburmeister
Apr 2019
augusta, ga
How do you go about implementing, on the M580 PLC, how many days, hours, minutes before a predefine event in the future?
The RRTC_DT yields the PLC datetime stamp in Datetime (DT ) format. Doing a DT_TO_ARINT type conversion gives the PLC datetime stamp (DT format) to an Integer Array of 4 elements with date and time in BCD format.
Example:
If the input is:
DT_Variable = dt#2006-05-11-10:46:16
Then the output is:
DateAndTime_ARRAY[1] = 16#1600
DateAndTime_ARRAY[2] = 16#1046
DateAndTime_ARRAY[3] = 16#0511
DateAndTime_ARRAY[4] = 16#2006
But dealing with arrays is tedious. Does anyone know a quick way to perform an excel equivalent DATEDIFF function on M580 PLC?
Also, the old 984 PLCs used to have a STAT word to check the health status of the various drops. Is there something similar on the M580?
Yup - you are correct! Upon further investigation, Modicon has a SUB_DT_DT function that compares to two DT values and outputs their difference in TIME format.
Ok, next question....is there a equivalence for the old STAT function.
How do i detect changes to the hardware (field devices, hardware changes, etc)
SUB? I'm pretty sure you just subtract one from the other and it gives you a TIME (duration) as a result.
Hi, I am using M580 PLC as modbus server and Scadapack 535E RTU as modbus client for a project. Both are connected via Modbus TCP protocol.I have...
2,296
Hi all, I'm really new to this. I need to export the Modbus register mapping from a Modicon M580 through Control Expert for the registers that...
948
We are now planning to upgrade from Quantum 140CPU11303 to Modicon M580. The software protect was written by Proworx NxT (.DCF). Is it possible...
998
Hi, Does anyone know if programming a Modicon M580 is basically the same format as an M340? Also do they use the same software package? Thanks...
1,775
I need to convert some Siemens PLC logic using Siemens TIA V16 to Modicon M580 logic. Is there a tool out there that will get me started? How...
2,687
