3 Phase 480 vac UPS units able to supply 15-20 amp .
Aug 2016
Virginia
343
Good Morning ,
Here in the mid-Atlantic area we are experiencing a lot of intense thunderstorms and many power outages. Do you folks know a good source for 3 Phase 480 vac UPS unit able to supply 15-20 amps . I would like to at least have a 3-5 minute supply or ride thru . During this time I can have a orderly shutdown of the machine . Also , what would be a rough price on this size UPS ?
Thanks so much , like always .
If you have significant lightning risk then I'd suggest considering surge arrestors your main incomer, and finer protection on sensitive loads like UPSs, Power Supplies and instruments.
I use Schneider gear here but there are other options. Look for a supplier that will do a site assessment for you.
I will be adding contact relays and current switches to a control panel that is majority 120VAC and some 480 3-phase. The coil voltage is 24 VDC...
2,602
Hey guys... I'm in the middle of a battle with the boss because when I try to tell him what I need he claims I don't know what I'm talking about...
2,976
i am building a couple of panels in my workshop and wish to do at least a simple checkout of them before installation. My workshop only has 240...
2,091
This may be a off topic of the site but I thought since I have gotten help here before that I might ask. I was changing a 480v 3phase motor about...
38
23,605
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
521
