Alarm/Horn Combination Unit - IP67
rajy2r
Nov 2006
Canada
167
I am looking for an Alarm/Horn Combination unit that will work in a steam environment (i suppose IP67 rated). Has anyone used something like this before.
Typically the issue with a combo unit is the holes for the horn let steam in and then it starts to rust.
I found the unit below, that should work i suppose, but hoping for something prettier.
http://www.e2s.com/system/1/product/pdf/13258/mca112-l1-alarm-sounder-led-beacon-datasheet.pdf
Would appreciate the help.
Thanks for the Info Guys. Most of the stuff is IP65/66 which doesn't seem to work in a steam environment. I have tried the Federal Signal SL600 and they don't last.
So far i have only found the Banner KL50, which is 50MM and is IP67 with the sealed light and horn, but i am hoping i can find something a little bigger for visibility purpose as this is for an outside application and not for a conveyor application.
Hello All, Can anyone recommend a panel mounted Alarm Sounder that is not annoying? I am not having much luck asking the Google Machine, so I...
2,175
I have an application where we want to install a PV+ in a control room. My question is there a version that has an alarm horn that triggers off...
2,420
Looking to silence an alarm from a HMI Button. Right now the HMI button command is set to Pulse the binary bit. Will the attached logic work to...
9,530
130
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
273
