hello.
i have an ac servo drive with 5000:1 "speed control range",maximum 10v
analog input setpoint and the motor connected to it is 2000rpm.
this means that the minimum speed of motor is 2000/5000= .4 rpm and the minimum allowable analog setpoint to the drive will be 2mv and below .4 rpm the motor can not deliver enough torque and will be stopped under load.
Do you confirm my understanding about "speed control range"?
best regards.
best regards.
