Beginner programmer
Nvious62
Jan 2020
Va
Hello all I am trying to learn some basic programming for my job. What I am wanting to do is on a Allen Bradley plc is write a program sequencing 4 lights with 5 second time delays between each light illuminating. The sequence will start when a “start” button is pressed. After 4 sequences all 4 lights will illuminate. Then sequence will restart when start button is pressed again. Any help would be greatly appreciated.
Ok thank you. Like said I’m a beginner and by that I mean really new to this. Is there anyway could go into a little more detail as to how I would do this.
Your description is missing some exact details, but this should get you started.
You didn't say what type of processor you where using, so this is done in Studio5000 V32 with tag names.
Ok so here’s what I come up with so far. I’m running cascading timers to make the lights work intermittently. Now I need to figure out how to get the mom push button to latch until it goes through the cycle and get it to count 4 cycles through the intermittent and then stop and all 4 light stay on solid. Then be able to restart it over by pushing the start button.
Move your start PB input to a rung before the first timer.
Then have the PB seal in a bit such as B3:0/0.
Add a counter that counts the number of cycles, when the counter reaches it's preset, it will break the seal mentioned above. Counter done bit is used to energize all 4 outputs.
Then if counter is done, PB input resets counter.
Dear all, First of all thanks for letting me join this forum. I just need some help in one of my programming exercises. Being a beginner...
609
Hi there :) I'm new here and in programming PLCs. Actually, the only time I've programmed PLCs were when I was in school eheh I will, most...
1,279
First I'm am using the logixpro trial version form the learning pit. I'm having some problems with a program. I need some help. It would be...
2,925
Hi ppl, I've just finished my second year studying Electronic & Computer Engineering @ Uni, in the UK. During summer, i'm involved in an...
5,766
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
248
