Can someone that can read Fuji HMI addressing explain this to me please
Greg7683
Jun 2018
Plainfield IN
355
How can the address in the picture work in the Fuji D 0304-E and not work with the Weintek HMI how does it use the -E because in the PLC program cant use the -E what am I supposed to replace the -E with been trying for 3 days no luck.
2011 mercedes e550 0 60
What PLC Model and series did you connect with fuji and what Weinte HMI model that you use.
I assume that you use Mitsubishi then config bit button as shown below by
use D_bit type and use format DDDDDDDh (D are D address and h are bit) that you use. In example D0304-E you need to use address at 0304E at address of D_bit.
attachment.php
attachment.php
We use FX2n and FX3u when I use that address as it is in the Fuji it says an error because of the - and the letter I was trying to understand why it worked on the same FX2n 128ES I think and not with the weintek HMI MT6070IH said something like address out of range I was able to get it to work by adding a 0 in place of the- and a number in place of the letter. I just followed how the addresses were in the first screen from the Fuji hmi went like 03047, 04308 down to 30400 I did the same for the ones wit the letters and it worked. if you know what I am saying lol
Thank you for sharing. For FX2N or FX3U format of D_Bit is DDDDdd when DDDD are Data Register address and dd are bit address (0 - 15) that if you use 0304-E it will be 030414 alright?
So if you know how to use the Weintek software can you answer me a question when using a numeric how can I get the keypads to enter a minus or a plus sign at the front of the numbers we type with the keypads for our positions I need it to read like as examples +245910 or -77394 in the numeric box on the screen.
Please follow this instructions.
1. Create Numeric Object.
2. Select Numeric Format.
3. Go to Data Format selected to 32-bit Signed.
4. Change Number of digits in Left of decimal Pt. to 6.
5. Go to Limits select Direct.
6. Change PLC Low to -77394 and PLC High to 245910
When you use 32 bit data register you should use 2 words to keep it If you use D0 to 32 bit then you should not use D1 in program.
Thanks but going from screen 16-17 and from 17 to 18 keeps not responding freezes up the hmi and freezes in off line simulation any reason why that is happening.I can't see whats doing I tried to make new function buttons but it is still freezing.
Maybe you should create blank screen at screen 16 - 18 and place only change page button then check result.
I uploaded some new arrow pic's how do I get them to push like a button I used them over a 2 state set bit but they don't push in like the rest. I meant I used them as the shape.
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
368
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
892
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,073
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,619
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,592
