2 elementary questions related to starting a program and connecting PNP sensors
Gianni86
Feb 2013
Lancashire
So, I eventually got a zelio to work with. 2 silly questions: Do I need a manual push button as an input to the smart relay to make it start executing the program? Or can I do that through the device's interface panel? I guess what I don't know for this is, say: I've downloaded the program to the device and I turn it on...will the program start running immediately?
Also having read this http://www.plcs.net/chapters/dcin25.htm, the model I've got only accepts 3-wire PNP sensors, so a sensor's Brown goes to VDC, Blue to 0 and Black to the input terminal. When I'll wire a SP ON-OFF switch, I'll do that between a VDC and the input terminal, correct? So, overall, the input device is the sink and the sensor is the source?
Regards
1. No, you do not need a push button to make the program run. I am not familiar with Zelio, but most PLC have a run command for you to select after a download. From then on it runs upon power up.
Then again, if you want the program to respond to a push button or so to execute a step, you have to program it that way.
2. Your wiring is fine
Regards
I need a double-pole single-throw relay in my application. I simply need two sets of N.O. contacts that close when the coil is energized. Nothing...
765
Hi All, Finally getting through the SLC brick project on the G304K- kudos to Red Lion for the fix, it does communicate with the brick!:beerchug...
2,503
Hi there! Want to do one elementary operation with KTP400. I have one boolean tag in PLC and want to set it then I push the functional key F1 of...
3,842
Hi all, Please refer to attached pdf. If a go with the second 2 disc configuration and apply the same clamping force as the original single...
2,985
Schneider Modicon Concept 2.5 Elementary Question Question - How do I copy the running Schneider Modicon Concept version 2.5 PLC program project...
7,896
