Red Lion DSP Virtual HMI click position
Ken Roach
Apr 2002
Seattle, WA
17,480
Hi guys,
I developed an application on a Red Lion DataStation Plus DSPSX device, which has a small "Virtual HMI" you can access via Web browser. This is super-useful for my application where I have to write a custom serial protocol and want diagnostic things to appear onscreen.
But I encountered something weird: when I put buttons onscreen, the cursor doesn't seem to go where I point it.
When I click on a button that is part-way down the screen, the button at the top of the screen (at the same X-position) receives the click.
... but not always. Maybe 1 time out of 5, the desired object will be activated.
I'm using Internet Explorer 11, on Windows 7 32-bit, inside a Virtual Machine. No other application seems to have any kind of pointer problems.
I also use the virtual "hard"/navigation pushbuttons and those work as expected.
I have never seen this on a G3 series physical HMI touchpad.
Has anyone else seen this on a DataStation Plus "Virtual HMI" ?
Try Chrome. I think I saw this with early versions of the Crimson Web Server when using IE. I have not seen anything too weird with Chrome, except when there is a big lag due to remote access VPN + wireless ISP, there is occasionally a half painted screen and slow response.
High five !
I was trying to keep the VM clean of extra stuff... but sure enough, Chrome works perfectly.
It was interesting learning about the Crimson "C-like" language in a little more detail today, and I was able to put together my little poll/response protocol driver in about 10 hours of labor.
I was so proud of myself until I heard from our field guy: "um, yeah, the custom RS485 interface boards all have burnt components, so we need to replace everything."
I'm still going to put in the DataStation Plus units in place of the MVI46-GSC modules. The old method had no error checking and required you to go online with the SLC-500 and cruise around the ladder logic and data tables even to count timeouts. Putting that data on a couple of browser-accessible screens will make them easier to check on when I get the inevitable "there's something wrong with the communications" call.
Awesome! Feels good to be able to help someone who has given so much to this community.
This is the set-up we have, and we recently lost comms to two devices on this PLC. After replacing the red lion and copying in another identical...
1,860
Greetings, I would like to print just five lines of data to a Zebra S4M printer. I would like to use the Ethernet Port, but open to suggestions...
1,554
Greetings, I would like to print just five lines of data to a Zebra S4M printer. I would like to use the Ethernet Post but open to suggestions. I...
1,292
Hey guys, I'm working with a PTV and am wondering if somebody knows of a way to log the info in the alarm/event viewer into a file other than...
1,719
Good Morning All, I am looking to sync a data log to a SQL server using a RL DSPZR. The sql server that I am trying to connect to is running on a...
3,018
