OT - Miniature DC Motor drive
Jim G.
Nov 2007
Georgia
187
Not necessarily a PLC question but could eventually turn in to one. I have an Automation Direct GSD1-48-10C dc drive set up driving 2 small 1/25 hp motors. The drive is set up for 24 VDC input and 24VDC out. The motors are rated for 12 VDC. I have the speed pot mechanically limited to only put out 12 volts to these motors. Seems to be working. This was a down and dirty response to a production request.
I only have 24 vdc available as a source in my panel, but would like to find a drive that only has a 12 vdc output. Can't seem to find one. Any recommendations? Needs to be able to fit inside a 10 inch by 10 inch enclosure.
The PLC part will come into play when trying to start and stop with the production line. Not concerned about that at the moment.
Thank you for your input.
Hi all, Does anyone know of any really small(Like 3in X 5 in) Display boards that can connect to Contrologix PLCs? A gateway to the device...
1,660
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
129
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
332
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
200
18
989
