Red Lion HMI with DL405
joeboucher
Nov 2013
Utah
I'm currently attempting to replace the HMI on an existing system with a Red Lion Graphite or G3 HMI. The PLC on the system is a Siemens Simatic TI435 (now sold by Automation Direct as DL405).
Is Red Lion compatible with this PLC? If so, which driver do I use, and what cable do I need? I'm having trouble tracking down the answer, due to the fact that this particular PLC has had a fairly lengthy history, having been sold by so many companies (TI, Siemens, Automation Direct) over the years.
There are DirectNet and K Sequence Drivers. For Siemens they list TI-500 series drivers.
That PLC was a Texas Instruments TI-435 and they don't list a specific driver for that unit.
I guess I don't really have an answer for you, but I do have quick access to the Crimson 3.0 configuration software if you want me to look for something specific.
Edit - a quick look at the Automation Direct Site says that the D4-4xx PLCs use DirectNet and K Sequence and the D4-450 has Modbus, too. I think you will be fine.
There is also a Modbus TCP add-in card you could use.
That's what I found too. Looking more into the PLC, it says that it speaks both DirectNet and KSequence, so it shouldn't be a huge problem.
Thanks for the help.
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
117
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
420
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
602
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,872
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,454
