Red Lion SN 6000 to remote Program ControlLogix PLC
nmurray
Apr 2014
USA
90
Hey, I have a SN 6000 setup and I was wondering how to / if I can connect to a controllogix PLC using a 1756-EN2T card.
I have attempted to set it up but I cannot view the device in RSLinx.
I believe how the SN 6000 works is you set the IP Address of the PLC and tell it which port it uses and which port you want that to be externally.
So I set up the PLC IP address in the SN 6000 web interface "Host Redirect (Port Forwarding) Rules" but still no luck.
Any help would be greatly appreciated.
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
263
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
218
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
110
