Hi Team,
I'm in the process of setting up a system with a SLC5/03 using Devicenet to communicate to (4) Panelveiw 550's and (4) sets of Flex I/O. The thumbnail below shows the configuration.
What I want to do is assign the SLC I/O address ahead of time, but I'm having a bugger of a time determining what they will be. I don't have a system put together to test on so I can not do any commissioning or setup at this time. As you can see from the drawing I assigned node addresses to each element on the network. The scanner module will be in slot 8 (the SLC already exist on a working line and I am augmenting the devicenet equipment to it).
Could someone take a look at this and make some suggestions regarding node assignments (if those I picked are not workable) and help me determine what the SLC I/O addresses will be. Any help will be much appreciated.
Thanks!
Thanks!
