Looking to send/recieve real time data between PC - PLC
vha23
Feb 2003
27
Hi, I'm pretty new to plc programming. My current project at work is to design a c++ program that will be able to communicate to an allen bradley SLC 505 plc via ethernet. ultimatly, i'm looking for the pc to recieve data from the plc, use that data to search an sql database, and then return a value from the database back to the plc. Is there any source code or drivers to do the communications? i would prefer freeware, just to see if I would be able to do it. Then I could spend money on a more expensive package if i need to.
Thanks a lot for all your help.
ABEL
Search for Ron Gage's ABEL - Allen Bradley Ethernet Library. It's a Linux-based set of programs for talking AB-ethernet. I have no clue as to how hard it would be to translate that to a Windows C++ platform.
But I'm not aware of any freeware communications drivers, but several companies sell communication drivers, some with downloadable demo versions which will work for a period of time or with limited functionality.
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
200
Good Afternoon , We all must of done this before ...... Installing a Frequency Drive in an enclosure , you forget how deep your selector...
103
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
219
Good Morning , Not sure how many use Markem-Imaje SmartDate X60 Printers , but I'm having trouble finding a good manual for...
353
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
118
