OT: Surge Supressors
lfe
Jun 2007
Barcelona
881
In the company where I work, about 10 days ago, a lightning storm caused the loss of power in the main servers rack.
There is a 10kVA UPS that worked perfectly but the problem was that several circuit breakers, including some differential, disconnected both upstream and downstream the UPS.
It seems that the maintenance manager is a bit clueless about how to try to avoid this in the future.
It seems that some Surge Supressors should be installed,
Could you give any guidance on the subject?
Thank you !
I am looking for surge supressors that I can install on existing hydraulic valves. Installation would be to sandwich them between the connector...
19
6,692
I just asked tech support at Phoenix Contact a question and the answer is making me think maybe I have misunderstood relay ratings for years...
2,858
I have a SC9-LS24-3 surge protection solenoid cable from automation direct...
1,348
Hi Folks, Is surge protection recommended for field wiring connected to PLC inputs? For example, I/O originating from field devices located...
1,166
by spec i must supply surge protection for each individual PLC input in my panel. These devices are all of the voltage free (dry contact type)...
2,244
