Rockwell Automation
richie
Aug 2005
new jersey
27
Are the courses helpful from Rockwell I plan to take an advance course in RS Logix 500 and plc program. This is a four day course I just would like some input I know this is the right place for this I am new at this.
If you are new to this I found the Rockwell training to be extremely informative and well executed. It always depends on the instructor but I haven't had a bad experaince yet.
Marc
i had a great experience, i did the controllogix fundamentals and rslogix basic ladder logic.
honestly i wouldnt have survived as far as i have without them. There are a lot of quirky things to know that are hard to figure out without making a mistake or having the instructor mention it.
also, the others taking the class can be very knowledgeable as well. I had zero PLC experience where most of them had been electricians for a while and had varying experience with PLCs.
It was a casual experience with the emphasis placed on making sure that you get the training in a way that you want. the instructor wasnt strict about following the lesson plan to a T whatsoever. He was very willing to dive into something that we had a question about.
Thanks I have a little experience at programming for I have RS lite and tried to do small programs to help my plant I do have the micrologix 1500 which does help on the hardware end but I did this on my own wanted to learn !!! so again thanks I WILL look over programs of yours and I think I asked this question before but is their a book on examples just to learn?
its hard to find 'examples' because most of the time PLCs are controlling a custom machine.
we make sawmill equipment, and while there are similarities, each machine is custom designed and therefore the program is custom.
for the micrologix 1500, the manual has some examples. also keep in mind that the 1500 uses the same programming as the SLC series.
i am in the same position you are in, just learning...
I designed and installed a saw that used the micrologix 1500, AC input, Relay Output, Analog output, and analog input (high speed counter)
the programming isnt too hard, just different than what i was used to. if you have any beginner questions about hte 1500, just shoot me a Private message if you think its too silly to post about.
good luck!
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
74
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
392
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
840
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
676
I have a problem with time sync working in this topology. I have a plc with grandmaster clock controlling motion groups. I wanted to add kinetix...
1,039
