Counters
John Cormier
Guest
J
:( Just a little brain dead this morning, In a Slc 500, looking to control an accumulator with a counter, Preset is set to 3, that is three objects go into a count and it will discharge one at a time. also three object will go into the accumulator, one at a time. I don't want the accumulator to go higher than 3. I don't know how to reset and have a count of three or less in the accumulator. When I reset it will go to zero. Thanks John C
John, put this rung right after the counter rung ....
  C5:0/DN                           +--MOV--------------------+
----] [-----------------------------| Source C5:0.PRE |---
| Destination C5:0.ACC |
This will keep the Counter's accumulator from counting up past its preset value ... which is what I THINK you're trying to do.
Also, in the future, use the LIVE QUESTION AND ANSWER section of the forum - you'll get a lot more help there. This is just the "practice posting" area.
Good luck,
Ron
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
157
Hey guys, thanks for reading. I am trying to use a micrologix(1000 or1500) to control 3 hydraulic pumps. I have a time clock to give a signal to...
38
3,466
iFIX 5.5. We have alarm count database tags with SIM driver and I/O address = "C:AREA-SD:ACK" which is suppose to count the acknowledged alarms in...
16
1,406
https://www.youtube.com/watch?v=zTOOYWMJg9M . Specifically see 1:46 to 2:11. 3. The Cell PLC is in constant communication with two other field...
3,159
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,716
