Omron CIO 54 Value
JuanPLC74
Feb 2017
Houston
23
I am modifying this program on a CJ1 Omron PLC.
CIO address 54 is under one MOV command that assigns it a value.
For the rest of the program that value is checked against other values with =(300)
However this address takes the value then start swinging between the assigned value and 0.
nothing else on the program is assigning a value to 54.
Is there a way to know where this assignment of 0 is coming from?
it is probably attached to a devicenet node, anybody knows how to take the node out of configuration
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
25
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
21
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
104
Hi, I am facing an error inside Omron Network Configurator. I have 2 PLC communicate each other using ethernet cable, send signal using Network...
90
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
84
