Panel View Plus 7 losing .mer
A_G
Jul 2014
MA
369
To make a long story short, my customer has a Panelview that had an application already running in it. I had trouble connecting to it from my laptop. So I shut down the running application and went into Terminal Settings. I could not find any .mer files! So then I rebooted the Panelview. Now I got a message saying there was no application in the Panelview. The application that was running a few minutes ago, seems to have disappeared completely! I ended up having to load a .mer file from a few days ago. It seems that all the .mer's stored in the Panelview have somehow completely disappeared. Anyone seen anything like this before?
Is it possible there's an SD card or USB drive inserted where the .mer files are stored?
I second this. I remember seeing 3rd party vendors who would load the application onto an SD card which would make it non-obvious at first.
To get to the SD, select the remote location from the Transfer Utility; the program should be there.
Let us know if that's not the case; I've never seen a PanelView lose files.
Cheers,
Vlad
There is a USB drive but there are no .mer files on it. There is no SD card inserted. When I tried using the Transfer Utility, neither the Internal Storage, nor External Storage 1, nor External Storage 2 showed any .mer files. I'll have to keep an eye on it and see if the same issue happens again.
Update: after getting error messages on bootup and talking to Rockwell tech support, they recommended to reset the Panelview to factory default. I'm about to start another thread on this. Anyway, in case someone has similar issues and sees this thread, I figured I'd update this.
Twice.
Once, the engineer had loaded the *.MER into RAM from a USB drive then removed the drive. The terminal ran fine for months, until it was power cycled and tried to load its *.MER from the now-absent USB drive.
Another time, the engineer had put a batch script on a USB drive that did an AutoRun to delete all the *.MER and *.LOG files on the terminal, as part of an initialization process. Somebody put that USB drive into the terminal, watched the CMD prompts fly by, took it out, and forgot about it. The terminal ran fine for hours, until it was power cycled and discovered it had no *.MER files, and the engineer found that killer USB drive in the cabinet and remembered what was on it.
Both times, that foolish engineer was some guy named Ken, who really ought to know better.
I'm not saying it's impossible for a PanelView Plus to "lose" a *.MER file (especially if there's a failing interface to SD or internal flash drives, which sounds like it has triggered a POST or BIOS error on your terminal) but when this happens, it is most probable that the *.MER was deleted or removed unintentionally from wherever it was in the storage filesystem.
Same here...:D
Downloaded the Runtime to 'Run at start-up', however, I left the 'Download as...' .mer Name box empty.
The terminal 'took it' as such and ran it happily, until, the same bonehead went about uploading it...Obviously, there was 'nothing' to upload...:D
Thanks, good to know there's a few things that can cause this and I'm not just going crazy haha
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
273
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
145
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
325
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
863
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
869
