CP 5711 9-pin serial port to PLC MPI 9-pin port communication cable.
hinddhindsa
Mar 2013
www.plckart.com
193
Dear friends .
I have is CP5711 siemens , it is having USB cable from Laptop to CP5711 Port. but does not have a cable from Other side (serial) of cp5711 to plc port.
Can your please provide me the cable pin out so i can build the cable for this.
Thank You very much in advance.
Cp 5711
The other end of the CP5711 is not a serial port, it is the MPI/DP port.
Mainly it uses pins, 3 & 8
Pin 3 is signal B
Pin 8 is Signal A
Be careful not connect an RS 232 Cable on that port.
Hagos
Should be an easy question. I just can't seem to search the right words... I just got a Siemens CP5711... one goes to the PC via USB cable. The...
2,480
Hi,Dear friends.i have SIEMENS CP5711 adapter.One side of this adapter is 9 pin female connector. can you please guide me about the cable details...
1,838
G
Why have Siemens at least two options? CP5711...
11,274
gordon
G
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
227
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
341
