plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 11th, 2018, 09:36 AM   #1
samvivi7
United States
samvivi7 is offline
Controlling DC drive with Siemens PLC S7-1500
Hey Guy,
I would like to control the (attached) DC motor drive with my S7-1500 PLC through an HMI.
when i say control i mean only the speed.
any help is appreciated.
Thank you,
Sam
Old January 11th, 2018, 12:00 PM   #2
Saffa
New Zealand
Saffa is offline
This controller appears to be very basic and designed for control using a 10k potentiometer. You would need a motorized potentiometer like high end stereo equipment used once upon a time.
Personally I'd look at finding DC motor controllers that accept a 0-10V or 4-20mA reference signal
Old January 11th, 2018, 12:30 PM   #3
samvivi7
United States
samvivi7 is offline
oh ! so not an easy one.
well, i will leave it as is. : (
Old January 11th, 2018, 12:46 PM   #4
janner_10
Supporting Member
United Kingdom
janner_10 is offline
Depends what the control voltage is returning on S2, if its 0v to 10v then you can simply substitute this with a PLC analogue output.
Measure across S1 and S3 and see if it's 10v.
Old January 11th, 2018, 01:36 PM   #5
samvivi7
United States
samvivi7 is offline
Janner10
thanks for the help. So i called the manufacturer and its 5V out and also they want me to use a Analog interface and isolation module.
since i cant spend any money on this (project) i will have to let things be.
thanks for all the help guys,
Sam
Old January 12th, 2018, 12:32 AM   #6
janner_10
Supporting Member
United Kingdom
Quote:
Originally Posted by samvivi7 View Post
Janner10
Sam
Doesn't really matter what they want, it's not their project.
Just restrict your 0v to 10v output from the PLC to a max of 5v. If your budget is zero, you haven't got many options.
Old January 11th, 2018, 01:58 PM   #7
damica1
United States
damica1 is offline
How many "Relay Outputs" can you dedicate to control the motor speed?
Build a Voltage Dividing Network, Example: put 5 resisters in series (lets say 2k each).
That would only cost a couple of dollars!
Now program the drive to have a min-max speed of let's 30hz - 70hz.
Now wire each PLC relay output in between each resistor, now just program your hmi with a button for 70hz, then one for 60hz then one for 50hz then one for 40hz then one for 30hz, with each turning on the associated relay output.
This would at least allow you to set various motor speeds, changing the resistor network would allow for different speed adjustments.
Just an Idea - this would cost no more than a couple of dollars!!
__________________
David M. Camp
Marshall Electric / www.mei-tech.com
PLEASE READ: https://www.prlog.org/12642091-marsh...-industry.html
PLEASE READ: https://www.prlog.org/12680572-marij...hold-word.html
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
siemens s7 plc communication capability panthripu LIVE PLC Questions And Answers 5 February 5th, 2013 03:33 PM
Citect SCADA with Siemens s7 300 PLC Einstein_86 LIVE PLC Questions And Answers 5 December 28th, 2011 08:28 PM
Siemens S7 225 PLC Internet Module ltrail LIVE PLC Questions And Answers 4 January 25th, 2011 12:55 PM
SCADA with S7 PLC by means siemens S7 PC/MPI cable Andoni LIVE PLC Questions And Answers 4 December 15th, 2008 07:04 PM
VT510 as HMI for Siemens S7 PLC? Angel Lopez LIVE PLC Questions And Answers 0 October 1st, 2003 11:09 PM
