how to transfer the HMI confort program of siemens
benz_mscp
Nov 2011
yes
Hi every body,
We have a defect touch screen TP1500 comfort " is accessible ",
we will transfer the HMI project form this one to the a new one,
are the same model TP1500,
We tried to upload the last program by USB with succes,
But during the dwoilding to the a new one we got an issue with incompatibility,
So I need your support,
Please be notified that we have a laptop and TIA portal, Prosafe and the broken HMI is accessible.
is it possible to upload a program from HMI?
thank's in advance
Best regards
Othmane
What is the incompatibility issue exactly?
You cannot upload a program from the HMI to the project in TIA. You can only take a backup and restore it.
What are the exact type numbers of the old and new devices ?
Be warned that Siemens Comfort panels exist in 2 versions. The newest just called "V2" to differentiate from the old.
An image of the old version panel is unfortunately not compatible with the V2 version panel.
You do not have the source program ?
Thank you for your quick feedback.
yes, i don't have a source program,
see below the references:
the existing old one is 6AV2 124-0QC02-0AX0
and the new one is 6AV2 124-0QC02-0AX1.
Thank's
hi CommissioningMan,
i have message like incompatibility and that's all,
Thank's
Kindly, we are trying to transfer a project to a new op77b, using Mpi cable with 187.5kb. The Set Pg Pc is detecting it, and the Op77b is...
1,874
Hi all I am trying to make some changes to a siemens touch panel (MP277 10") numeric display item which is displaying incorrectly but I need to...
1,313
Hello Everyone, I'm working on a couple of systems that use Beijer HMIs. One system uses a Exter K20m, I connect to it using RS232C serial and I...
2,137
Hi everyone I'm having trouble transfering a projec from my PC(wincc Flex 2008 sp2 Win7) to an HMI simatic panel(tp177b pn/dp 6"cstn). I 've...
3,554
Has anyone been able to use the ME Transfer Utility to Upload an application from a pc based FTView 6.0 installation? AB is very vague in the...
3,107
