Tark said:You know what would be nice? If we had someone on this form who knew a thing or two about elevators.
elevmike said:Ok folks gotta hot date tonight so have a good one...
darrenj said:Thanks Mike...Damn elevator in that building still gives me the willies...Stoped on me twice today..desended slowly till it hit 15th floor then took off up to 19...Scares the living **** out of me every time!!
I hate heights!!
D
elevmike said:Warning: These machine rooms are VERY DANGEROUS. There's lots of exposed high voltage D.C. and unguarded moving machinery. Snag you pants on a hoist cable and your entire body will be reshaped to fit through a 6" x 8" hole instentanously. Stand too close to a flyball governer and you'll end up with a compound fracture of the tibia. Touch ANYTHING on the controller and you'll dissapear in a poof of smoke. In short, I dont need a video...I've already seen it, thanks anyway.
elevmike said:Fred,
As it turns out many very attractive looking, well built, systems seem to be designed entirely in open loop (no feedback) analog control.....(not to mention a lot of RFI from unknown sources).... This requires quite a bit of mainteniance and frequent very very fine tweeking, which involves a fare amount of trial & error. Lack of documentaion is also an ongoing problem....
You can be as gentle as a kitten, but never forget that your dealing with a man-eating lion.
elevmike said:I always take the stairs wherever possible!
Actually elevators are statistical something like 1000 x safer then stairs. As a matter of fact they are more then 100 x safer then the next safest form of transportation, (air travel). Per passenger mile.
elevmike said:Word of Warning.. These systems are potentially explosive..Espesially if you have 2 systems running at the same time..
Darren, I've never had the guts to try maintaining multiable systems. This is due to the fact that when others that I know do attempt this, the two systems always seem to link via a broadband comm network, which usually brings both systems into a disreparable condition.
