New Here, Have this PLC stuff, but not sure where to start, or what it all is.
jeff000
Jul 2010
Alberta
Ok I managed to salvage this from demo, I know its a PLC with a screen, but no idea what it is really.
The one grey cable goes to the lcd screen. The other was cut off, no idea what it is but it is labeled "MBPlus" the one to the screen is "Modbus".
Opposite the yello numbers are some LED's.
This is the side, its really the only thing on it.
modicon pc-a984-145
This is some other ports, I think for expansion?
This is the screen
A search for modicon pc-a984-145, seems like its a PLC, but I have no idea how to program it or well anything about it. But a search of the quickpanel jr seems almost like the screen is the PLC and the other thing is well I dunno.
Can I program from the screen?
I have a 120VAC to 24VDC transformer for it.
I am wanting to basically set up a PLC for my fish tank, I know a PLC for my tank is overkill, basically a timer for the lights, and controls for the pumps and auto top off things like that.
I was going to just use a Idec Smart Relay, but because of work this fell into my lap. But thinking I should just sell this for the smart relay, seems its worth more then the smart relay.
But I need to start with knowing what this all really is.
I'm a commercial electrician, I have run control wire and mounted PLC stuff but never turned one on.
Thanks for any help.
Looks like the QUICKPANEL jr. is only a HMI from which you wont be able to program the PLC. You'll probably need to have a software (modsoft if I'm correct) for programming the 984 PLC. HMI is just used to input data to PLC and aslo to display data from PLC. Hope that helps.
Seems almost like I find conflicting data about this stuff.
I'm just going to sell it I think and buy the Idec Smart relay, where would be a good place to sell?
Thanks.
Where is the best place to sell it? Or better yet trade?
How much is the software and cable that I would need for what I have?
126
I just graduated as a mechanical engineering student, and started this new job a controls specialist with a company in my area. My coworker has me...
962
Hi, There's a problem I face with upgrading the OS from XP which has the Step 7 Lite installed to windows 10. As I can't use a cracked version of...
617
We have this sub-system that was installed back in 2009, was never used, the building that used it was shutdown shortly after installation, and...
1,161
Yes or now and if yes what would you include or test for as a minimum standard? I can think of things like DeMorgan's theorem Karnaugh maps -...
60
23,157
