David Cook
Hello all, I have gained much from browsing the forum over the years. I am an industrial electrician which at our factory which means anything from light bulbs to RsLogix to HMI's. I understand about 1 in 10 posts but have learned lots so thanks already!
I have been able to successfully set up and run a powerflex 525 over ethernet on a slc505. Our controllogix processor in our shop is a 1756-l55/A version 16.
I have found info on adding with version 20 and have downloaded the add on profile and can bring them up and use them if the project is version 20. When I use version 16 the downloaded profiles do not show up in my list of available modules to add.
I have searched high and wide and now come to you. Is there any way to add a 525 to version 16 and if not can this processor be flashed up to use 20?
