NGCPLC
Hello,
I am modifying a program for a 1756-L61 controller using Logix version 20.01.
I am trying to add or change datalinks for several of PowerFlex 70's but there seems to be a glitch with the software. If I go into the module properties and set the datalinks they will not update in the controller tag database. After many attempts, Logix has randomly accepted the addition of some datalinks (e.g. Undefined A1 and Undefined A2) and updated the tag list but I have yet to discover the mechanism behind this.
This is an older processor so we can't take it up any higher on the version.
Does anyone have a work around to force Logix to update the tag list based off of the module settings? I assume if we started from scratch and deleted the modules and reinstalled them then it would possibly take but I would hate to go through that for 30 or so drives.
An example of the parameter we are trying to see is "Fault1Code".
Thanks.
Thanks.
