I've setup another VM with KEPServerEX but it will not talk to the same PLC that the other is. It is seeing the PLC as it will show another error if I take the VM off the network but when it can see it there are a bunch of CIP errors for each tag.
Using the Allen-Bradley ControlLogix Ethernet driver in KEPServerEX to a 1769-L33ER PLC.
I thought maybe it was the version of KEPServerEX, but I upgraded to the same version that's running on the two that are working and that didn't help.
It's like I'm missing a setting, but I've double checked the channel settings and the device settings a couple of times and they look identical to the one that work.
Warning Allen-Bradley ControlLogix Ethernet Channel4.WPLC | Unable to read tag. | Tag address = 'B25:10/2', CIP error = 0X4, Extended error = 0000.
