GE Proficy EGD question...
Voltimus
Jun 2004
Deep in the heart of Texas
177
I tried the GE forums for these questions but I haven't gotten any reply, so I'm going to check here and see if anybody can help me out a little, since this is where the people who actually use the software are at.
I was wondering if anybody knows if there is a way to export variables (tags) from one project to a .csv file and then import the list into the consumed exchanges part of the EGD on proficy machine addition.
And could anybody tell me what the limit of variables is for consumed and produced exchanges in a Proficy project are?
I've been kind of feeling around in the dark for this information and any assisstance would be greatly appreciated.
Thanks,
Nick
You can Import/Export *.egd files but not *.csv format.
http://forums.ge-ip.com/eforum/showpost.php?p=58328&postcount=2
Also use Proficy's online help by selecting "Ethernet Global Data" in the Navigator window and press F1.
In laying out your data you can try using the "EGD Management Tool" if you do not have a 64bit OS, but I find that using Excel and manual setup simpler.
You can setup each PAC's exchanges in the data collector CPU or in each CPU or a combination. Lay out the map on paper, use addresses rather than symbolic variables keeping them sequential as much as possible will minimize the number of exchanges needed and keep the data flowing more smoothly.
Haha...that was my thread on the GE forums.
Thanks for the help, Russ...it's greatly appreciated.🍻
I have a project where i have two rx3i plc systems seperated by fiber with fiber\ethernet media converters. Both processors are IC695CPE305. My...
1,141
When attempting to upload the hardware configuration I get the message everything was uploaded succesfully but in the message center I get this...
1,756
I have a fairly simple system consisting of a VersaMax PLC, a 6" HMI panel, and a Fanuc robot. I am trying to configure these to communicate via...
5,906
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
38
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
90
