Peak Modbus TCP slave/server simulator not communicating
danw
Oct 2004
midwest, USA
3,427
Installed Peak V3.0 Modbus/TCP slave/server simulator on Windows 10 box.
Configured a couple registers and attempted to read from it with a box that moments before was used as a slave to Modbus Poll master on the Windows 10 box, so the Ethernet network is functional.
The app window (upper left, above) says no client present, and the communications monitor (below) is blank.
The master is polling once a second for the two values and gets no reply.
Windows Defender Firewall shows two instances of the app, one with the private network access disabled, the other with private network access enabled (highlighted in blue).
I attempted to change the unchecked instance one to "enabled", but the settings are greyed out, I can change the settings.
Any suggestions? Can the unchecked instance block the app?
Dan
Seems clear that the firewall blocks the connection.
Settings are probably grayed due administrator rights are required to change them.
Have you tried to use the "Change settings" button ?
I've been doing Modbus for 20 odd years but almost never do I have to use a slave simulator. Until today. I used Peak HMI's freeware RTU slave...
1,944
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
136
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
676
I have an analog flow signal that fluctuates with many peaks and valleys. Occasionally due to valve changes a peak value (or several) will be way...
1,239
I have an application where I need to know the peak pressure of a machine and time at peak pressure. I am wondering does anyone know of an...
1,572
