seymour_andy
I'm Trying to install RSLOGIX 5000 V19.01, soon after install begins i get the following errors in log file.
MSI (s) (9C:18) [12:30:53:539]: Deferring clean up of packages/files, if any exist
MSI (s) (9C:18) [12:30:53:540]: MainEngineThread is returning 1603
MSI (s) (9C:F0) [12:30:53:561]: RESTART MANAGER: Previously shut down applications have been restarted.
MSI (s) (9C:F0) [12:30:53:562]: RESTART MANAGER: Session closed.
MSI (s) (9C:F0) [12:30:53:562]: No System Restore sequence number for this installation.
=== Logging stopped: 06/03/2012 12:30:53 ===
MSI (s) (9C:F0) [12:30:53:563]: User policy value 'DisableRollback' is 0
MSI (s) (9C:F0) [12:30:53:563]: Machine policy value 'DisableRollback' is 0
MSI (s) (9C:F0) [12:30:53:563]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (9C:F0) [12:30:53:563]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (9C:F0) [12:30:53:563]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (9C:F0) [12:30:53:563]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (9C:F0) [12:30:53:564]: Restoring environment variables
MSI (s) (9C:F0) [12:30:53:564]: Destroying RemoteAPI object.
MSI (s) (9C:A0) [12:30:53:564]: Custom Action Manager thread ending.
MSI (c) (10:24) [12:30:53:566]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (10:24) [12:30:53:567]: MainEngineThread is returning 1603
MSI (c) (10:14) [12:30:53:571]: RESTART MANAGER: Previously shut down applications have been restarted.
MSI (c) (10:14) [12:30:53:571]: RESTART MANAGER: Session closed.
=== Verbose logging stopped: 06/03/2012 12:30:53 ===
Setup Plugin: *** System Update logging end ****************************************
Setup Plugin: End RSLogix 5000 OS update: update failed: 1603
Can anyone help ?
Andy
Can anyone help ?
Andy
