575v or 600v to 24vdc
Many comments and thank you for that!
Regarding the eaton suggestion it wont work since:
Nominal input voltage
3 x 400 - 500 V AC
It will tolerate up to 600V but that is vecause ot has 20% tolerance. But if I supply 600V I would need tolerance from that input also. The same seems to apply for the Rhino series. It seems the best bet is to use a transformer down to a lower voltage first would be the beat option.
The eaton supply lists:
3 x 400 - 500 V AC
So I'm not sure it would work.
EDIT:
Oops, I see someone already posted this.
3 x 400 - 500 V AC
I see, yeah transformer down might be the way to go. Only other thing I have come across is the following.
https://www.elliottelectric.com/Media/PSS55C-CHC-2
Seems to claim the PSS series has options for 600VAC nominal.
It looks like Newark has a leftover and they want to get rid of it. Their regular price is $1006.72, pretty close to Allied's. The 160 watt version shows as "not normally stocked."
3 x 400 - 500 V AC
I realized this after I got excited about it on Friday afternoon. Still need to include a transformer in my panels. Humbuggg!
I return to my original reply to the OP of.... It doesn't exist! Not on my shelf anyway.
Hi all, I have a client that is trying to save money on generation costs. They have decided to run their generator on different speeds and so our...
3,726
Hi all. I am needing to spec out an AC Variable Frequence Drive to go on a machine destined for Ontario, Canada. The industrial power in Canada...
20
7,779
Hi everyone: we have Baumuller AC drive BM4463 300A 160KW, it drives Baumuller AC motor DST2-315BO54W-020-5-A (90KW;RPM 200; 365V; 215A;83Hz)...
361
Customer wants to put 3 phase transformer beetwen 600V VFD and 220v motor. Is it going to work?
22
8,503
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
417
