Using Profihub B4F02 in Ring Topology
Engineer_UA
Oct 2016
California
43
Greetings,
Is it possible to network together multiple Profihub B4F02 and host PLC using fiber optics in a ring network configuration. I've got SCADA PLC and multiple profihub devices scattered around multi building facility.
Any input would be appreciated.
Thanks,
EE
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
54
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
115
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
221
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
58
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
104
