![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Feb 2020
5069-l310er ethernet cutting out shortly after power up
Hi all,
Im having a weird problem with my panel and i think its the plc causing it but it could be some other component. When i power up my panel it all lights up happily and looks fine, plc goes into run all looks good. But after maybe 10-20 seconds of the plc being in run i notice all of the remote io and inverters go into fault displaying B073, loss of ethernet. This is happening pretty consistently but not every time, i was staring at the plc while it powered up this last time looking for something but i didnt see any error appear on the plc display. As far as i can see im not losing my 24V power supply or something that might be turning my ethernet switch off |
#2 |
The first stop in troubleshooting intermittent network connections is the L310ER's web page. Type its IP address into your web browser and look over some of the ethernet statistics. Post screenshots if you can. Pay attention to any miss/rejected packets, FSC/Alignment errors. The page changes between controller models and possible revs, typically there is an Application Connections tab that displays information for each device, make sure there are no missed/rejected packets.
I find that leaving all devices at AutoBaud produces the best result.
__________________
Open source python communications library for CompactLogix/ControlLogix/Micro800 PLC's: https://github.com/dmroeder/pylogix |
#3 |
![]() ![]() Join Date: Feb 2015
Did you try replacing the Ethernet cable connected to the PLC?
#4 |
Ok so changing the ethernet cable did not solve it, and i could not connect to the web server.. do i have to enable something through studio 5000?
#5 |
Silly question but is the port you are using set up for DLR ?
__________________
≈ There are 2 kinds of people in the world... (1) Those that can derive answers from incomplete Data |
#6 |
i dont think so.. but i dont really know.
I have A1/A2 on a static IP and my network topology is linear/star |
#7 |
Oh right you do have to enable it at some firmware rev, they disabled it by default. Someone they knows off the top of their head, or has one in front of them might have to chime in. I don't remember where you have to enable it.
__________________
#8 |
![]() ![]() Join Date: Feb 2007
I just looked a project that I have with 5069-L306ER (ver 32) and I could not find anything to turn on and was able to connect by typing the IP address of the controller into Internet Explorer.
#9 |
tried it through edge just in case it was firefox, got a refused to connect error
https://imgur.com/a/RW2UZot |
#10 |
![]() ![]() Join Date: Sep 2015
Could it be a duplicate IP Problem?
#11 |
If it was duplicate IP i expect the problem would be constant, i have also used NMAP from nmap.org to check all of my network devices, no duplications
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
To Latch Or Not To Latch | BOWRIDER | LIVE PLC Questions And Answers | 43 | October 21st, 2015 06:19 AM |
Power cycling issue | rta53 | LIVE PLC Questions And Answers | 2 | August 17th, 2006 09:35 AM |
Plc Rack And Power Problems | plcnovel | LIVE PLC Questions And Answers | 7 | May 30th, 2006 05:51 PM |
IO power with ethernet | TConnolly | LIVE PLC Questions And Answers | 7 | January 25th, 2006 11:56 PM |
Analogue Inputs - Sink, Source, Help! | Yabadabadoo | LIVE PLC Questions And Answers | 14 | January 26th, 2005 02:48 PM |
