I would like to build a gas engine pull start test machine. I envision a electric motor with a large cam or pulley. Pulley diameter would be T=f*d. Force ~ 200 lbs. Torque = motor torque.
I need to control rotation. Depending on pulley dia. might start at 0 degrees and stop at 90 degrees.
Needs to have at least speed control. Big person would pull fast and a little person will pull slow.
Force control would be a plus. To do a programed profile to match a actual pull start would be the best.
Any recommendations on a type of motor needed and control system need?
