Balluff BNI 006A
PLC_
Mar 2021
michigan
Good afternoon guys,
Having a little trouble getting my 8 port I/O link master block to communicate with my processor. Its a BNI 006A MB connected though a 8 port tp link switch.
switch is connected to an ent2 rev 5.002. keying disabled. ent2 is in a rack with a l82S. I can ping the MB, I'm also plugged into the switch. I set up the MB as a generic ethernet device, used the manual to set up the correct input and output sizes. installed the EDS as well. the problem I'm seeing is I cant seem to get a real connection to this block, I keep seeing connection timed out flashing in the module fault window.
i know the block is communicating at least to me. not sure where to go from here. any help or ideas is appreciated.
there isn't a Balluff Specific ethernet device for you to use instead of the generic ethernet?
Balluff does have an EDS option, but the generic device option works also.
Could you give us a picture of the device configuration screen? Just to get a picture would be nicer.
Also, what are the IP settings of your PLC, are you sure it can communicate with the module? In order to have a connection via an unmanaged switch they need to be in the same subnet.
I have a Conveyor System Running Balluff Remote Ethernet blocks Topography has ethernet going through Master-2 to Master-1 (BNI...
399
Hello, I have a balluff network i/o block, BNI EIP-538-005-z063, and I can't establish a connection with it from my PC or PLC. I tried pinging...
348
I have been attempting to find an answer for a couple weeks now and I am almost to the point of calling Rockwell, but I figured I'd give it one...
1,197
Hi. I was wondering if any of you guys have a problem with the RFID reader/write BIS M-4A7-082-401-07-S4 from Balluff. The problem we are...
653
Hi All Has anyone gotten the 856T-B24LC to work on a Balluff BNI-EIP (BNI006A) or 3rd party io-link master? I have the IODD file loaded and can...
1,290
