FactoryTalk View Studio SE Alarms & Events timestamp question
jmveerkamp
May 2012
OH
23
I am using FactoryTalk View Studio SE and using the Alarms and Events Summary included. I am logging alarm events to SQL Sever Express 2008. My problem is that when events are logged, they are timestamped incorrectly. They come in with a timestamp 5 hours greater than the event happened.
I.e. if the event happened at 3:30PM the timestamp in SQL would say the event happened at 8:30PM.
If anyone knows of a setting I am missing please let me know.
Johnny
The Eventtimestamp in SQL gets the time from PLC that is a UTC time not Local time on your Server or PC. But if you use objects in FT such as alarm and event summary, log viewer etc. You will get local time because it is converted from UTC into Local time. You can see date/time of PLC in RSLogix5000 and Controller Preoperties dialog box, on th Date/time tab.
Gesios
Gesios
Hi..
I am new in AB and found same problem.
I use time in PLC (UTC + 5:30) and in PC same (UTC + 5:30) but still I got difference in SQL Database.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
131
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
260
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
677
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
625
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
459
