FactoryTalk View Studio Getting data from other software
Apr 2011
Manila, Philippines
295
Hi Guys,
Overview:
HMI: Factory Talk View Studio 7.0
UPS: (GE) GT8000 RT comes up with software for monitoring
OS: Windows Server 2008 R2
We're currently doing a project wherein we need to monitor the UPS status, the issue comes up when the module for dry contact is not available, leaving the PLC and the HMI "clueless" on what's the status of the UPS.
Since the UPS comes up with a software, wherein it displays the status of the UPS as well as its alarms, Is it possible for FactoryTalk to get data from the UPS software so that it will be able to display alarms in the HMI environment?
Thank you!
Does the UPS support SNMP. If it does then you could use the Kepware SNMP Client driver to connect to the UPS and read he data. More importantly if it does then it can probably send a Trap to the driver when an error state occurs.
This is assuming that the UPS has an Ethernet Port.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
131
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
260
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
677
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
625
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
459
