3d printer
42 inch by 42 inch and height about 10 inches. Looking at speed of around 140 inches per minute. Not really sure about resolution since we have just starting discussing this, but as accurate as possible.
Actually at the moment looking online at 3d printer kits and trying to decide what kit to purchase. Trying to find one that uses nema 34 size steppers.
I am going to recommend you look at OpenBuilds.com
I just bought a new frame for my new laser etching machine I am building from them.
https://openbuilds.com/?category=3d-printer-builds&id=272
There are a lot of designs on there that can be scaled up. They also sell alot of components. Sounds like extruded aluminum V slot/rail setup and using a belt drive to the stepper motor may be a flexible solution. Just a matter of making a solid enough bracket for the motor and aligning it with the belt/pulley system.
Also I have ordered parts from Mitsumi.
https://us.misumi-ec.com/
They have lots of parts at those lengths that would work.
Here is a possible solution for the motors and drivers
https://www.omc-stepperonline.com/3...-driver-and-power-supply-3-ma860h-34hs46.html
Just would have to look at the interface to stepper drivers. Looks like they support PWM so should work with Marlin firmware.
Hope this helps a bit.
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
57
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
177
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
369
Shot in the dark here, but a customer has this Arca Linerplus Advanced 4.0 printer/applicator for pallet-tagging and we need to change the mode on...
127
Hi All, I currently have an issue to establish connection between my PLC to Zebra Printer. On my side don't have the ASCII card Module to use...
756
