Hej.
If You just need to log the data, then there is no need for textboxes.
It is op to You, where You what Your DATA to bee stored. You can make your own variables to hold the data or write them to a file.
Private Sub SaveData()
On Error GoTo SaveData_err
Dim intFilNr As Integer
Dim strFilName As String
intFilNr = FreeFile
strFilName = App.Path & "\" & App.Title & ".TXT"
Open strFilName For Output As #intFilNr
'(You should Use a loop to save the data)
Write #intFilNr, "Data"
Close #intFilNr
Exit Sub
SaveData_err:
MsgBox Err.Description
Exit Sub
End Sub
Best regard
Jesper
