Unable to load Program to HMI
qwemx
Jul 2017
Earth
195
Hi All ,
I am trying to download a program to HMI , I am able to detect the HMI on searching for the compatible devices from the TIA portal V13 SP1 , i have connected ethernet cable directly on the HMI ethernet port , HMI is getting detected but when i hit the load button it gives me error 0132 :000002
HMI model is Siemens MP277 10" TOUCH INOX
6AV66430ED012AX0
I am able to make the HMI screen flash by selecting the Flash LED option
i also used prosave to restore the HMI to its original condition
the loader version is V01.01.04.00_01.16 i tried to upgrade it using prosave but it says Ok
my HMI is in transfer mode
also used crossed ethernet cable
the problem is fixed
i used the wizard to configure the HMI
i deleated HMI and added again this time i hit finish to skip wizard and was able to connect
Hi all, I am ready with a small program to be downloaded onto a ML1100 PLC. I have set up RSLinx and using the RSLogix Micro Starter Lite edition...
1,594
Hello i have already created an HMI program for the TP1500, and i want to download the program to the panel and it seems to be no connection at...
2,097
I've a problem with program downloading in CX programmer. When I begin to download the program I get the message "Unable to download program(s)...
18
11,430
Hello everyone, I currently have a problem on one of our machines. I cannot download the S5 program. I only can upload it. Only DBs are downloaded.
5,444
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
223
