Possible to use InTouch Symbol Factory in Archestra Graphics?
phuz
Jun 2008
Mohnton, PA
1,044
I'm working with an application that has to be done in 2012R2, so it doesn't have the situational awareness library and I find that the built-in graphics are limited. The Symbol Factory within InTouch offers quite a bit, but I see no way to access those symbols from within the Graphic designer in the App server.
Any way to import those?
While using WindowMaker, generate a smart symbol from a symbol factory graphic. Then in you Graphic editor under the "special" tab, you can import InTouch smart symbols.
I haven't tried this, but in theory, it should work.
That's what I was afraid of. Seems like a lot of work to get all the symbols imported that I'd want to use.
I ended up purchasing the 4,000 piece symbol factory for ArchestrA... and never used any of the graphics!
Dear Intouch and Siemens experts, My system: S7-300 PLC CPU 315-2DP....one port is connected to E910 Mitsubhisi touch panel and the other to IBH...
3,151
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
205
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
333
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
169
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
810
