Major Hault error code
rajat303
Feb 2018
india
I have Micro-logix 1200 . whenever i run the program online it shows faulted.
and it shows the " User Define Error Code ". i checked the code and the code is
Ok. Please tell me whats the problem.
Thank You
welcome to the forum.
it's early for me and I just finished a call from work, so here goes.
go online and look at the error and tell us what it says.
what software version are you using?
what model of cpu and firmware?
james
I am using RS logix 500 and RS links with ML 1200. whwnever i am going to online and run the logic it shows Faulted wioth red indicator and It show User Define Error code. 0021H
Can you post the program? on the bottom of the page in RSLogix it should tell you what rung your error is in
0021H is not listed as an Error Code, so a "User-Generated" code may be what you are seeing.
You may want to examine status words S:20 and S:21 in your routine to pinpoint the file and rung number where the fault occurred.
There you may find a SUS (Suspend) instruction, with 0021H or 33 decimal as the defined code.
Hello, We have a customer with a 1756-L72 ControlLogix PLC. They have recently got a T01:C62 Fault Code. I am trying to figure out how to...
1,041
Hi Guys Today we went through the worst situation that PLC went to major fault Mode due to Trap by one of the Timer with -ve Value Moved into...
1,018
Hi, We are having issues with an intermittent Major error code 21h. The plc can be running for varying amounts of time before faulting anything...
1,881
1756-um004_-en-p From the manual above, 1756-EN2TP supports PPP communication, and the 1756-EN2TR has an embedded switch. Is the EN2TR embedded...
2,801
Hello everyone, has anyone had this problem before PLC 5000 Model 1756-L81E Major Fault Type 4 Code 20 (T04:C20)
4,269
