Program Last Edit Time
gwyklevrsi
Aug 2018
Michigan
Hello,
Is there a way to determine the time in which either the last online edit or full download to PLC has taken place in rslogix?
Best,
Gabriel
Not without either.....
1. Having code already in place to monitor Controller objects using GSV. There is an "AuditValue" which can be configured to update on certain changes to the controller. That's a cheap option.
2. Having, and using, FactoryTalk AssetCentre software. That's definitely not cheap....
Not sure about the download but the Controller Properties Window/ File tab has a Edited time stamp.
Which I'm sure could be got with a CIP Generic Message, if you only knew the Service code, class and attribute numbers....
Option one here will work perfectly for the application, thank you for the help!
AuditValue was meant to work both with sophisticated validation management systems like AssetCentre, but is exposed to the user program via the GSV object so it can also be used by ordinary CYA "when was it edited" applications.
The object was released with RSLogix 5000 v20, so it's available both to L6x generation controllers and to all current and future controllers.
This is the reason why I signed up here and decided to get some help before I tackle the traffic light program on Wednesday. It looked good on...
17
11,690
Hello All, Is there any way to program a ZEN 10C1DR-D-V2 so that it will resume from its last know state before a power interuption, which could...
2,109
Hi, Has anyone check how long a SLC program (5/04) can last in the CPU without battery & EPROM? The PLC is not power on. One of our customer...
3,817
Unregistered
U
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
31
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
76
