Load cell - Failure due to unexpected power cut off
Rather unlikely, the only thing I can think of is that the power supply gave a peak voltage at shutdown.
How did the power supply fail? What components are you connecting it to? Are you sure it is really the load cell that failed rather than the circuit you connect it to?
Have you checked resistance across all connectors on the load cell? When disconnected, you would measure similar resistance across all internal "resistors" that make the load cell:
between ex+ and si+
between ex+ and si-
between ex- and si+
between ex- and si-
Typical resistance would be around 350 ohms.
Much more details for checking load cells can quickly be found online, e.g.: http://www.loadcelltheory.com/troubleshoot.html
I have to agree with Toine, it's hard to imagine that affecting your load cell. Now, your scale is a different story...
Did anyone do any welding in the vicinity of the scale?
What type of loadcell and indicator?
Good Afternoon, I’m limited with a skilled maintenance staff to design and build Load Cell , Rollers , etc. for conveyor sections . Do...
659
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
837
Can someone recommend an Intrinsically safe barrier that can be used with an "ANALOG" load cell on a weigh scale? Load Cell is rated to be in a...
1,370
Hello All, I have two bags of two different types of peanuts hanging on a load cell above two separate feeders. I am using Studio 5000 and would...
45
8,837
We have a web converting process that involves the web passing over rollers with load cells on each end. This provides a tension readout from an...
2,488
