Siemens S7-200 conversion
bill4261
Jan 2005
mid-west
99
Can Anyone convert an old Siemens MicroWin program to version 3.2 or 4.0? I don't have the older software. I believe its 2.0.
Thanks,
Turns out it was just names of the SBRs and INTs that needed changing (ex: SBR_0 to SBR0, INT_0 to INT0).
See attached... not sure if your CPU type in the project is correct, since I didn't see it in V2.0. Just match it to yours. You should be able to upload in V4.0, you just won't have comments.
Thanks.
I also found out that Version 2.1 is included on the V3.2 and V4.0 CD's. Here's the steps to convert.
1. You need Step7 Microwin 2.1 to open the file.
2. Deselect Symbolic addressing.
3. Switch to STL view.
4. Save the program.
Thanks again gclshortt and sigmadelta
I need to convert some Siemens PLC logic using Siemens TIA V16 to Modicon M580 logic. Is there a tool out there that will get me started? How...
2,687
Hi i need help in converting Time to S5time in S71200, in s7-300 converted using T_conv Thanks in Advance Ragu
5,331
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
250
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
127
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
179
