KEPware Allen-Bradley Controllogix Ethernet - How to Read ASCII file
Tanquen
Jul 2014
CA
163
PLC is ControlLogix 1756-L73 CPU with firmware 28
In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT.
In KEPServerEX I tried:
Char A60[110] = -1
Char Array A60[110]{5} = -1,-1,0,0,0
Short A60[110] = 16724
String A60:110/4 = Unknown/Bad
This will end up in an InTouch app and it is using a string tag with the address A60[110]{5} but read it as a long number: 1672420512000
Can you move that data into an actual STRING datatype and use InTouch to read that ?
It sounds like it was almost certainly translated from a PLC-5, which had a special ASCII data type. The ControlLogix doesn't have an ASCII data type, but can show the contents of SINT, INT, or DINT arrays in ASCII format.
What is your application; do you just want to display a string, or do you have to process it or enter a new string in InTouch ?
Yes the old PLC was a SLC with a CompactLogix 5370 L3 series processor.
Not sure if I can move them to a string.
The existing InTouch application is using a user input with an I/O Message tag and the address A60:110/4
I found an app that they have already upgraded and the address in InTouch looks like this: A49[0].DATA/10 @STRING
The "A49[0].Data" suggests that it was changed to a STRING datatype, because those have a .Length subelement, and a .Data[x] subelement that is a SINT[x] array.
The "/10" suggests InTouch syntax that designates the string has a fixed length of 10, rather than having InTouch read the .Length subelement
"@STRING" is probably InTouch syntax designating this reference as a String data type.
Unfortunately I don't know much about InTouch string displays and entry objects.
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
118
Im trying to get data from AB guardlogix controller using Kepware in a remote location but it seems that version 6 can only support contrologix...
411
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
605
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
373
Im using Kepware for comms between a Panelview 1250 and a power transducer via modbus tcp. Im a little confused on the Kepware software, Im using...
783
