Batman42
Hey Everyone,
I'm using studio 5000 version 33.12
The plc firmware is 33.012
I have this plc model: Compactlogix 5370 1769-L16ER-BB1B and when I connect to it with a simple program in studio 5000, It will not let me download the program to the plc and I get an error saying:
"The controller acknowledged the request for a transition to Remote Program mode, but it has not completed the transition. You can't download until the transition completes." Error 747-0
The Plc has a steady green Run light, but on Studio 5000 there is no Run light. In Studio, I do not have the option to switch back to program mode. The key switch is in Rem mode.
I see no faults at this point, however if I let the plc sit for a while it will give me a fault 16x0203 which is an I/O connection timeout fault. I don't have any extra I/O cards installed on the unit, it's just the internal I/O on the front, with no expansion modules.
Is there a way to factory reset the plc to factory settings, wiping all settings, ip configurations, etc? I have tried removing the SD card and holding the reset button on powerup, but the ip and internal settings remained the same.
Any help or leads on this is appreciated, thanks!
