Allen Bradley 1756-OB16D Red OK Fault Fix
Mr.Robot
Aug 2016
Westchester
Hi all,
Have couple of AB 1756-OB16D modules that are faulted, poss power surge, as soon as insert into backplane, pre-check tests start, initially OK indicator goes green, then constant red & brings communication to controller down.
Connected to controller using RSLogix 5000 over Ethernet.
Looking for a way through software/hardware to investigate this further & reset the modules to factory default if possible & start over.
Thanks in advance.
260
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
141
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
202
Dear All: I have the flashing red light on the FDBK indicator. The manual said that it means: The axis servo loop error tolerance has been...
635
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
899
