plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old July 2nd, 2005, 08:07 PM   #16
just_lionel
United States
just_lionel is offline
just_lionel's Avatar
Ive always wanted to learn German and Russian. Looks like Italian would be something else good for me to learn. (We have alot of German and Italian equipment. I always wanted to learn Russian for some odd reason)
__________________
just_lionel
The sooner you fall behind, the more time you have to catch up.
Old July 3rd, 2005, 09:54 AM   #17
sapoleon
Argentina
sapoleon is offline
hi
just a little correction... the dictionary page is
http://dict.leo.org/
there is other german dictionary that I like, it is not only to english in:
http://www.pons.de
other page I sometimes use is
http://www.freetranslation.com
and btw, I would like to learn japanese. I started, made one year of the six, and have to leave it because i moved... twice really. must start again.
__________________
I am responsible for everything...
except my very responsibility.
J.P.Sartre
Old July 4th, 2005, 10:38 PM   #18
Unregistered
Guest
Posts: n/a
fun with languages
Quote:
Originally Posted by rsdoran
Thats how German works. English (at least ours) has over a million words in the vocabulary, German (Deutsch) has around 80,000. They put words together to create words to express ideas.
In this case you are seeing the verb "fahren", which means to ride or drive (run but not jog type). They use things like abfahren to mean not run, not drive etc...stopenfuhr or something along those lines would mean "stop running" or "stop the drive"....it has alot to do with context, in this case a machine.
BTW its probably stoppenfuhr, stoppen means to halt, freeze, stop running and a multitude of other decease and desist type applications. I am use to Anschlag, or some variation thereof, for the estop.
Maybe some one that actually speaks the language will chime in.
actually, it seems like the oxford dict has something like half a million words in it and the duden, which is the standard reference for german language has only a fourth of that. in my opinion that does include the agglutinated words, but i might be wrong.
as for putting words together to make new ones: i think the very same happens in english, doesn't it? except in english you don't write them together. like: 'foerderband' == 'conveyor belt'
'stopenfuhr' doesn't make any sense to me. close would be 'stop einfuhr' which could be a badly translated (maybe from english?) 'infeed stop'. what was it supposed to mean?
'abfahren' is to depart (i've never heard anybody using it for a machine, but then i'm not working in germany, so maybe somebody does actually use it). do you mean 'anfahren'? that would be to start (a machine or production for example) - but it also means to hit a person with a car, btw.
'not-aus' in my opinion is an emergency power off, while 'not-stop' is stopping (probably actively) the machine. maybe i'm wrong, but i would think that if your machine room gets flooded all of a sudden it might be better to hit the 'not-aus' than the 'not-stop', since i figure that stop means to stop and not neccessarily to cut the power supply afterwards.
'anschlag' is something that is used to hinder movement further a certain point. is that a block in english?
well, i've got some problems of my own and maybe some of you guys could help me: those dictionaries are all very nice but they never tell you about whether that word is right for the context. can somebody please tell me the correct verbs for the cycle of a pump?
it fills ampoules from liquid in a tank. so when in the first phase the pump is filled with the liquid is that 'to suck in'? 'to charge'??? then the pump stops moving for a moment while the filling needles are lowered. is that a 'resting position', 'dwelling position'??? now the fluid is forced out of the pump - 'discharge'? 'evacuate'? and, since we don't want that drop at the needle's tip to fall into the ampoule, we move the piston slightly up. what's that called? 'sucking back'?? that's what one of my co-workers came up with. sounds funny to me but, i don't know better.
anybody? thanks in advance!
Old July 4th, 2005, 11:16 PM   #19
Eric Nelson
United States
Eric Nelson is offline
Eric Nelson's Avatar
Quote:
Originally Posted by Unregistered
...can somebody please tell me the correct verbs for the cycle of a pump?
Any of the words you chose would be appropriate. In the first phase, I would choose "charging" over "suck in". Actually "filling" or "prefilling" (the needle) would be fine also.
The 'resting period' could be called "dwell" or "wait position", or even "charged" as the step following "charging". Maybe "filled" if you use "filling" as the first step?
I think "discharge" is the best word to decribe emptying the needle.
Although funny, "suck back" is a common term that would be easily understood.
I'm sure others might have suggestions as to better 'descriptive' words for these steps...
-Eric
Old July 5th, 2005, 02:49 PM   #20
trojan_goat
United States
trojan_goat is offline
trojan_goat's Avatar
Correct word in German for "Emergency Stop" is
"Dringlichkeitsanschlag"
Push the Emergency Stop Button!
Betätigen Sie die DringlichkeitscStop-Taste!
__________________
To design is to communicate clearly by whatever means you can control or master.
Old July 5th, 2005, 10:01 PM   #21
Unregistered
Guest
Posts: n/a
thanks a lot Eric, now i can deliver my documentation with less fear being laughed at..
-> trojan_goat, sorry that's exactly why i was asking the questions. your 'dringlichkeitsanschlag' is pretty funny and not comprehensible, while 'dringlichkeitsstop' would be understood by most i guess, but still sounds funny.
('dringlichkeitsanschlag' would translate in sth. like 'urgent block' with block being sth. physical. 'dringlich' is rather 'urgent' than an emergency. as i said, i would suggest 'not-stop', or maybe 'not-aus' - where 'aus' means 'off'. (in my opinion if sth. stops the machine then it should be -stop and if it merely switches it off it should say -aus - but maybe that is standardised somewhere.))
stop used to be written 'stop' but now it has been changed to 'stopp' by the bureaucrats (there's no phonetic difference). traffic signs still say 'stop', though...
Old July 5th, 2005, 10:16 PM   #22
Unregistered
Guest
Posts: n/a
hungarian phrasebook for engineers
"i will not buy this record, it is scratched!"
??? "...ahh! main motor inverter overload!"
Old July 5th, 2005, 11:31 PM   #23
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
This is one of, if not the main reason I am taking deutsch. I have worked with several German built machines from different manufacturers and in several cases they used different terms for the same application.
For ESTOP I have seen these terms and more:
anschlag - with more than 1 term added with it.
Not-Aus also Not-Aus-Einrichtung
Nothalt
Notschalter (I think this may be a southern Germany/Italy thing.)
I worked on machines made in Germany that had English on the controls and display but the plc program is in German. It uses "stopp" ...Stopp Messer (knife). These programs were written before the changes in the german language were made.
My comment pertaining to the vocabulary (maybe thats the wrong term) were not stated derogatorically, it was a statement based on what my Instructor and my class book stated. There are differences and that is one of them...has nothing to do with good or bad...if one is better or worst. They are both languages that many people use in their everyday life but I do not know deutsch yet but that will change.
Alles gute. Viel Gluck. Ich habe eine examen auf Deutsch morgen früh.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old July 6th, 2005, 03:41 AM   #24
Ken M
Scotland
Ken M is offline
OK, unregistered, you're not the only one who thought of this!
Surely we're not alone ...!
http://bau2.uibk.ac.at/sg/python/Scr...rasebookSketch
Old July 6th, 2005, 09:58 PM   #25
Unregistered
Guest
Posts: n/a
Nothalt
hey rsdoran,
i didn't take it derogatory at all. it's just that since i'm terribly curious i tried to get more sources for the information and apparently the numbers are a bit different. which i don't really care about, but i thought you might be interested in the information. according to the oxford dictionary's web page (and wikipedia too, btw) - "that type of" english has half a million entries. which is an amazing lot, i think. http://www.oed.com/tour/step-2.html
merriam-webster has apparently fewer words (470.000)
according to the duden homepage, which is supposed to be the authoritative source for information about german language, german has about 125000 words. and that does apparently include words that are being put together (agglutinated?). would be interesting to know, why there is such a huge difference, regarding both of them are pretty closely related and underwent more or less the same influences (at least in europe, i guess). i'm kind of curious as to why that might be. anybody with a linguistic background wanting to share his insight?
also i think too, that there's none of them inferior to the other. the concepts are simply too similar to give any of the two an advantage (like not being able to express certain things or making differences between different times of action etc. - once a friend asked me, how germans could get by with so few tempi...). and given each of them has many times the amount of vocabulary a human can memorise there's no real gain in having more, i guess.
stopp was a spelling mistake until recently, btw.:
(in case anybody actually cares)
http://uploader.wuerzburg.de/rechtsc...o-a-z.html#s/S
'notschalter' and 'nothalt' are both valid in my opinion. there's probably not much need for bikeshedding about this. after all, if it's still comprehendible and there's always worse. for example: the japanese write 'wheel' as 'hooiru' (put the stress on the 'i', then it makes a bit more sense) which took me a while to figure out.
good luck with your exam.
-> Ken: thanks for the link. interesting resources..
should a new thread for ranting/making fun about internationalisation issues be started? could be fun from time to time. also i could use some new automation jokes.. anybody?
Old July 7th, 2005, 07:41 AM   #26
RMA
Scotland
RMA is offline
RMA's Avatar
The reason for the use of two "p"s is because "stopp" is the imperative of the German verb "stoppen", to stop. As you say, this was the case, even before the recent changes in German spelling and grammar. As far as the traffic "Stop" sign with a single "p" is concerned, I suspect this may have more to do with international standards than anything else.
Old November 19th, 2019, 02:53 PM   #27
JRW
United States
JRW is offline
JRW's Avatar
memding
This was 2005
and our friend Ron passed away
Old November 20th, 2019, 05:06 PM   #28
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Please don't use our technical community forum to advertise your essay fraud scam. It's especially galling because you chose a thread started by our old friend Ron Doran.
Fortunately you're weak and lazy and it doesn't take much effort to ban you.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
STUDENTS ATTENTION -- from a student leitmotif LIVE PLC Questions And Answers 57 February 21st, 2005 01:34 PM
????? SeanLee LIVE PLC Questions And Answers 39 June 23rd, 2004 06:41 PM
Paper comments-Diagnostic System to PLC dandrade LIVE PLC Questions And Answers 0 March 10th, 2004 03:49 PM
Student needs help BDKuhns LIVE PLC Questions And Answers 11 October 4th, 2003 02:44 AM
Paper Press Rewinder rsdoran LIVE PLC Questions And Answers 14 September 23rd, 2002 10:59 PM
