Siemens TP900 Comfort: VBscript logging vs datalog
userxyz
May 2002
any
2,768
I have a request from a customer.
He needs to log around 10 real value's.
The interval must be changeable.
He wants to be able to take the files from the card without dataloss.
So I was thinking, maybe I should write a script to create record logging and
recreating a file each day with the date in the filename. In the script I will need to close the file at the end
to be able to copy the files to USB when they want. The interval is easy this way because I manage the trigger in the PLC.
Questions:
- An interval of 1s for example, would that work okay with scripts like this ?
- Anywone did it this way ?
The other method is the datalogging of single tags. Sure this can be done... but these are active files... so when copy to USB I would need to stop logging and then do the copy because the files are not closed.
- Is the interval changeable of datalogs in an HMI...
Thanks,
Kind regards,
C
I need to confirm that the can we convert the KTP1200 Basic PN to TP1200 Comfort HMI. I am using TIA Ver 14 and it shows the Device change option...
2,238
Hello everyone, I have issues on programming Siemens HMI TP900 Comfort. hope to get everyone help! After download program to HMI, I selected...
5,234
I have a Siemens TP900 Comfort Panel in a system, successfully monitoring data from a S7-1200 PLC, a couple of S7-200 PLCs, and an AB SLC5/05 PLC...
4,215
115
134
