S7 - identifying Screen Number in WinCC Flexible 2005
RMA
Sep 2004
North of Hamburg, Germany
2,052
Identifying the currently active Screen Number in ProTool is pretty easy, but so far I haven't been able to find a simple way of doing this in WinCC Flex. I've worked around the problem so far by setting Marker Flags on entering a Screen and then deleting them on leaving the Screen but I don't really like it.
Does anybody know if there's an inbuilt function to identify Screens Numbers in Flex (so far I haven't even been able to identify a Screen Number in Flex, never mind find a function to read it!), or alternatively has anyone any thoughts on a more eloquent way to achieve the same result.
Edit:
I've now discovered the successor to ProTool's Area Pointers under Communication and Screen Number is a pre-defined Area-Pointer, so that's no Problem just assign a DB and off we go.
Still leaves the big question, how do I find out which Screen Number WinCC Flex allocates to a particular Screen?
Hi Roy.
In the project tree, you select the desired screen and right-click with the mouse, then open the properties from the menu.
In the "general" group of properties is the "Number" setting.
For all other objects, alarm messages, tags, connections etc. you get a nice grid view of all the various properties, but not for the screens.
Another one for the wish-list.
Edit: How could you have missed it, it is in the same dialog as where you set the "Loaded" and "Cleared" events ? Need stronger glasses ? ;)
Hello, I'm looking for a source for the white connectors in the picture below. This controller has 6.3mm spade connectors potted into it in rows...
1,434
I have seen the canned transfer functions that are used to teach and transform a function from the (s) domain to the (t) time domain, but how can...
2,781
Attached is a picture of a PLC from the mid to late 80's... It is currently running a machine that is struggling after a power disruption. Can...
22
8,365
Hello everyone, I want to indentifying harware of a B&R Automation PC online to diagnose and set an encoder for the B&R ACOPOS servo drive but...
1,498
I have a CompactLogix 1756-L72/B with only an EN2TR/C in a 4 slot chassis. Port 2 of the EN2TR is connected to two POINT I/O racks, while port 1...
1,906
